Yo ledzilla,
FYI, suggest you grab one from a yard;
here are the full range of our Big Broncos' external carriers
Y
●Swing-Away, Type 1 (78-86); "...Brackets have sharply angled straight corners to match the older body. 87-96 have smoother curves..." by Steve
Swingaway Spare Tire Carrier Types '78-96
IF THE IMAGE IS TOO SMALL, click it.
Specific year ranges are approximate.
FOTZ-1432-A Carrier frame
EOTZ-1478-A Hinge, upper '80-86
EOTZ-1479-A Hinge, lower '80-86
EOTZ-1A398-A Latch
FOTZ-1A429-A Spare support
F1TZ-1A401-A Reinforcement plate, strike
F4TZ-9845026-AAC EB tire cover
N803515-S (A1-65-A) Swing Pin Bushing
C5TZ-2461-A
NOT SHOWN
Rubber Bumper for 1469 Type 3
Types 2 & 3 require a locking lug & key (386) as shown here:
TSB 90-07-13
Publication Date: March 28, 1990
LIGHT TRUCK: 1990 BRONCO
ISSUE: High latching and operating efforts of the swing-away spare tire carrier may be caused by a lack of lubrication on the latch and striker assemblies.
ACTION: Lubricate the swing-away spare tire carrier latch and striker assemblies. Refer to the following procedure for service details.
SERVICE PROCEDURE
1. Make sure the spare tire carrier is latched. Both the primary and secondary latches must be engaged.
2. Spray multi-purpose grease (D7AZ-19584-AA) onto the latch mechanism located on the vertical bar of the swing-away carrier.
3. Make sure the tailgate striker is in the full up position and square. Do not allow striker misalignment.
4. Close the carrier.
* Both the primary and secondary positions must be latched.
* If the carrier does not latch, re-adjust the tailgate striker as required.
5. Lubricate the roll pin on the striker and the portion of the striker which engages the rubber sleeve on the carrier.
PART NUMBER PART NAME
D7AZ-19584-AA Multi-Purpose Grease
