82 ford bronco rear window issues
spm69mjm
82 ford bronco rear window just stopped work checked fuse switch seems ok remove cover off tailgate and i dont see any signs that its in a bind ......... two wires coming off the motor red/yellow tried jumping and just got sparks any help would be great thanks
Reversing the leads reverses the direction of the motor. If you jumpered it and nothing happened, the motor is bad. If you heard it running when jumpering then the gears are bad.
$100.00Bronco
Tooele, utah
Is it just me or is it bad window season?
Im just trying to get one on the road as cheap as posible that as been just sitting for six or seven years becouse the owner didn't want to mess with it. So far I,ve spent $100.00 for the Bronco, barrowed a battery, and put on my Kia's winter tires and have been driving it around the naighborhood. I have bought a few things that will be going on this week.
Dennis
snowman74
Oklahoma
If the motor is good, and the gears are bad (which IS a common failing on those motors) then the gears aren't too hard to find or replace. Be sure you **** it well, and don't get any dirt or stuff in when you seal it back up. If it's the motor, I've seen them on Ebay for around $50-60 new, but not Ford manufactured. Local salvages might have good used ones. LMC Truck also sells them, and the gears. You can find the gears on Ebay too.
Snowman74 :)>-
Ford644
