'79 44 front
95wrangler
I don't have a Bronco but I do have '79 front D44 I want to swap in my '95 Wrangler. What I want to know is, what is the width on the 44 from wms to wms. I have heard 65" and 68". My jeep axles are 61", I would like to keep the 44 full width. Thanks For your info.
Cmprice
if you have it why dont u just measure it?
78 BEAST
Colorado Springs
It is 65" and some change, but you can cut the tubing and make the length the same as your rear end. Then you just get the shafts from a 77-79 Jeep Wagoneer if I rember correct.
STLKIKN
Calgary Alberta
J**p TJ Wrangler with f.s. D44 and 9", wheels are 15x8 with 35 12.5 Goodyears...
Quite a bit wider than your rear diff.
STLKIKN
Calgary Alberta
Same idea here, but EB 44 and 9", also in a TJ Wrangler.
36s on 15x8s.
Baltimore773
