I am having some trouble with my right rear lights only, the rest work properly. When I turn on the parking lights it works correctly. However, when I press the brake or signal (to the right) it goes out and the brake element does not come on. When I turn the parking lights off the right signal turns on the parking light element but not the signal element (pressing brake does the same as the signal).
I have changed all bulbs even the ones that worked. I have traced the wiring as best as I can and find no damage (I even removed the trailer wiring kit). I have checked the grounds with no problems. I used a test probe to see if there is power at the bulb and it shows that it should work but with a load (plugging in the bulb) it does not work correctly. I have only glanced at the switch but not taken it out or checked it over yet. I am planning on going through the switch next unless anyone has suggestions. I have ordered a repair manual but it has not arrived yet. I'll be going over the wiring diagrams as soon as it gets here.
Please help if you can.
