'78 Bronco Rear Window
J
james
Guest
I own a 78 Bronco, its a great vehicle and in pretty good condition. I have one major complaint however, the switch on the inside of the truck that rolls up and down the rear window doesnt work; but the key switch does. Is there any ideas you guys could give me about how to make it work, I have a pretty good knowlage about wiring but this has me stumped. Any help you could give me would be great thanks.
Ziggy
Riverside, Ca
James,
Replace the switch with a momentary "on-off-on" switch and then transfer the wires over from your old switch to your new switch. You may want to check the various companies (LMC, Bronco Graveyard, etc.) first that carry parts for 78-79 Broncos. The Ford P/N of the switch is D8TB-14529-AA. Ford may still carry this switch if it had more then one application.
Ziggy
Root710
