Broncoholics
Broncoholics
Most might know this but Tom's Bronco Parts sells a fan shroud for those with 2"-3" body lifts for $100.
I run a 2" body lift so the stock fan shroud doesn't fit unless I drop the radiator 2" to match up with the engine. The easy fix was to buy the 2" body lift shroud.
Winter I run electric becasue of deep water. The electric don't keep the motor cool enough in summer so I go back to the mechanical fan. Without a fan shroud it would overheat. A radiator shield is another good option when using a mechanical fan so the fan doesn't go through the radiator. This can be made in your own shop for $10.
