Broncoholics
Broncoholics
I was thinking about stretching my 68 Bronco wheel base and adding Dana60's. Wouldn't it be easier to buy a F350 and put a Bronco body on it and add coil overs, gears and lockers?
I'd cut the front and rear frame off so they don't stick out.
This way I have D60's, the length I need to reach when climbing/ stability and the tires will stick out ahead of the front and back for good departure angles. I'll get inset rims so I'm not too wide like the Hummer rims. I'm not worried about high centering with a 6" lift and 38's with clopped fenders and rock sliders.
My buddy put a Toyota body on a Blazer so he would have the V8 and wide axles. The only tough parts were the pedals, steering and dash wiring. After that it works pro locked up and stock 4:11 gears.
What do you think?
What do you think?
