5.9 Cummins in a Bronco
AdamDude04
Anyone do a swap yet with a 5.9 cummins motor?
My buddy is putting this in his 67 F150 and it's really got me thinking. I assume it would fit.. what all would be needed to make it work? I'm sure an axle swap to deal with the power..
yo
Yep, I have a few install LINKs in my site under ENGINE, DIESEL
some excerpts are;
Installation Information, 5.9L Cummins; "...A 6 cyl. 5.9 Cummins engine will fit in your full size Bronco, but if you have not already beefed up your front suspension you will want to do so. A minimum fix is a good set of air bags for your coil springs. Other options, if not already done, include a solid front axel or a heavy suspension lift. The full size Ford Bronco takes all of the same Ford Cummins diesel conversion hardware as the F Series Ford pickups of the same year..."
Source: by fordcummins.com
Installation, 5.9L Cummins in a 91 (owned by Paul S (Swamp Thing))
Source: by Jason S at http://www.dieselpowermag.com/features/ford/0810dp_1993_ford_bronco_powerstroke_diesel/index.html
ok, Comcast decided to slow CONN speeds down to dial-up level circa 1986
A
AdamDude04
Thanks Miesk5! Great information.. seems like you and a few others on here really know their stuff! *thumbs up*
bbs_jeff
Arkansaw, WI
I'm going to try and swap a 7.3l into my '94, but I was planning on swapping the full suspension too, from either a F250 or F350.
digs
