5.0 Throttle bodies
snowman74
Oklahoma
What's up y'all,
On the 1987 5.0, there are what look like dual throttle bodies. The mass-air-conversion uses a Y-pipe to reduce those two to one pipe for intake. What I want to know is, would there be an advantage to replacing the throttle bodies? If so, how large diameter should I go? I notice there are twin bodies on the plenum stock...but all replacements seem to be single bodies. Do you buy two of them? Thanks.
Snowman74 :)>-
It is a twin bore TB; also described as a 2 valve unit..
some notes for you:
"One of
the biggest misconceptions about throttle
bodies is that installing a high-flow
unit (whether larger or of an improved
design) will result in a gain in power.
Building a better throttle body, or at
least one that flows more air than a production
piece, is oftentimes a simple
matter of increasing the flow area. By
this we mean that a 70-mm throttle body
(like the 2-valve unit from Ford Racing)
will usually outflow a smaller 65-mm
version ...
piece). Unfortunately, the simple fact
that one throttle body outflows the other
does not guarantee power gains. Power
gains are only realized by increasing
the flow through the motor, not just
improving a single component. The
exception to this rule is when the single
component happens to be the restriction
in the system that is limiting the engine
snowman74
snowman74
Oklahoma
Thank you for the info Al, that is precisely what I was looking to find out.
Snowman74 :)>-
