4 inch lift-what size tires?
tship87
Maryland
Right now I have a 4 inch lift on my 94 bronco and have 33 x 12.50 tires. I have seen some broncos with 35 x 12.50 tires and am wondering if they will fit comfortably or not and if there needs to be some modification (other than getting fender flares), such as cutting the bumper. Any help would be appreciated. Thanks.
Krafty
Ontario Canada
as far as I know, you should have no issues running 35's on 4" of lift, I have 33's with no lift, and I've heard 35's on as little as 2" so you should be fine. but the appearance with the bigger lift with 35's I find is more appealing
T
tship87
Maryland
I had to push my bumper out some to fit my 33s...maybe because they are 12.5 wide
stusainte
01085 Ma.
I have a 95 with a 4" suspention lift and 35x12.5 x15 s allterrains and the only issue i have is full turn to turn rubs on my sway bar thats about it and did have to pull the fairing aff the bummper good luck
Ricky B
So Cal and Baja
Just don't forget about your gear ratios--nothing worse than a 5000 lb. tool shed with the equivalent of a 3:09 rear diff....... :rolleyes:
digs
