4/3 3/2
WileE7
What and where are the 4/3 & 3/2 circuit they are from dtc 67
yo dude!
confirm it is 67,
cause KOEO 62 - 4/3 or 3/2 pressure switch circuit failed open - E4OD excessive converter clutch slippage
KOEO 67 = Neutral safety circuit failure (Transmission Manual Lever Position (MLP) sensor circuit)
KOER 67 = A/C circuit was on during KOER Self-Test is
the code 62 can be generated by
excessive converter slippage or a delay in the electronics
or hydraulics. If the trans has ever been re-built, especially
over the past 5 or 6 years with all the updates, it is
likely a slipping converter. If this is the case and the
trans works fine otherwise, you may be able to replace the
converter and let' er rip. If you have to replace the
converter, look for one with the latest HD clutch. I have
the LUK in mine which was custom built. It locks a bit hard
but gets the job done. There are other causes of a code 62.
The electrical wiring can be checked pretty much from the wiring
harness if you have an ATSG manual for it. You should be
able to find the manual online. I get them from the local
parts supplier for about $14 each.
Lugnut
WileE7
WileE7
yo dude!
confirm it is 67,
Lugnut
what do i do about a code 67 how do you fix that. my transmission works fine i have almost 190,000 miles on it i was told i should have it rebuilt and change the converter but if i don't need to i don't want to but if its good preventive maintenance i'll just knock it out what do you think
E4OD MLPS Water Intrusion of, TSB 95-2-12 by Ford for 89-94 via miesk5 (Al M) at comcast.net
Water Intrusion of MLP/TR Sensor TSB 95-2-12 by Ford for 89-94
01/30/95
TRANSMISSION - E40D - DIAGNOSTIC TROUBLE CODES - WATER INTRUSION OF THE MLP/TR SENSOR
TRANSMISSION - E40D - POSSIBLE WATER INTRUSION INTO THE MLP/TR SENSOR CAUSING SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS
TRANSMISSlON - E40D - SHIFT CONCERNS AND/OR HARSH ENGAGEMENT CONCERNS DUE TO WATER INTRUSION OF THE MLP/TR SENSOR
1989-94 BRONCO, ECONOLINE, F-150-350 SERIES, F-47, F-53, F-59
ISSUE: Some vehicles may exhibit a shift concern and/or a harsh engagement concern due to water intrusion into the MLP/TR sensor and vehicle harness. There may also be a number of different DTC's along with those concerns.
ACTION: Replace the MLP/TR sensor and vehicle harness connector if signs of water penetration are evident. Refer to the following for service details.
SERVICE PROCEDURE
1. Verify the customer concern.
2. Perform normal on-board diagnostics.
3. Inspect the MLP/TR sensor for signs of water contamination.
4. If water penetration is present and/or DTC's have been set, replace the MLP/TR sensor and the vehicle harness connector with the TR Sensor Service Kit (F5TZ-7A247-A).
The TR Service Kit contains:
One (1) TR Sensor
One (1) Connector Assembly
One (1) "Red" Pin Separator Plate
One (1) 6-Pin Grommet
One (1) 8-Pin Grommet
One (1) 7-Pin Grommet
One (1) Instruction Sheet
PART NUMBER PART NAME
F5TZ-7A247-A TR Sensor Service Kit
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage For 1992-94 Models, Basic Warranty Coverage For All Other Model Years
OPERATION DESCRIPTION TIME 950212A Perform Electronic 2.0 Hrs.
Transmission Diagnostics, Replace MLP/TR Sensor
DEALER CODING BASIC PART NO. CONDITION CODE 7F293 08
E4OD MLPS pic & Failure Causes by motorcraft.com http://www.motorcraft.com/products.do?item=9_9
Why a Transmission Range Sensor May Fail
Time and usage
Prolonged use in extreme temperatures
If the electronic circuits to and from the sensor and to and from the engine control computer module are malfunctioning
Related Components to Check
Electronic circuits to and from the transmission range sensor
Electrical connections to and from the engine control computer
E4OD MLPS Removal Discussion & Tips by fullsizebronco.com
ck for broken shift cable as described here too;
http://fullsizebronco.com/forum/showthread.php?t=27530
E4OD MLPS pic w/Alignment Marks (from a Mercury, but similar) by Steve83
http://www.supermotors.net/vehicles/registry/media/81709
WileE7
WileE7
01/30/95
SERVICE PROCEDURE
One (1) TR Sensor
Time and usage
i have a 17 bolt transmission pan isn't that a c6 transmission? i have a 90 fullsize w/302 and its 4wd forgive me if i sound unintellgent when dealing with these problems this is my first time doing any real car maintenance i'm used to working on jet engines
no problem, been there too!
unless someone swapped it out it is an E4OD;
look @ Chris's Pan Diagrams to confirm;
http://www3.telus.net/cbradley/TransIDChart.JPG
E4OD has 19
C6 Does have 17
and by Baumann
The E4OD four speed automatic transmission is used in F and E series trucks, as well as AOD and AOD-E/4R70W four speed automatic transmissions. To determine which is used in your vehicle, follow these guidelines:
If the shifter has a P-R-N-OD-D-1 pattern, the transmission must be an AOD (applicable to 1980-1993 vehicles).
If a 1989-1993 truck has an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, then it is equipped with an E4OD transmission. With the possible exception of some 4R70W equipped 1993 E-150 vans with 5.0L SFI engines (The existence of a 1993 4R70W van is unsubstantiated).
1994 and later vehicles with four speed automatic transmissions will all have an Overdrive Cancel Switch and a P-R-N-OD-2-1 shifter pattern, but may have either an E4OD or a 4R70W transmission. All 4.2L, 4.6L and some 5.0L engines use the 4R70W transmission, while diesel, 4.9L, 5.4L, 5.8L, 6.8L and 7.5L vehicles always use E4OD
WileE7
WileE7
E4OD has 19
C6 Does have 17
and by Baumann
don't think it is the prob...do the Self Test again and figure out what Code it is.
and more info on loss of power such as; when..when engine is cold,
or all the time;
at any speed?
any harsh shifting thru gears?. etc.
WileE7
WileE7
or all the time;
at any speed?
its any time sometimes it doesn't want to shift and i have to shift it myself once i hit 15mph i lose power and i have to lightly step on the gas to get it to accelerate sometimes it feels like its jumping between 1st and 2nd when i start out. when i initally drive its fine but once i hit 15mph it starts flipin out
ok, do the Test again and make sure it is 67; if it is..I'll be away until Monday,, look at my site for AODE info and DTC possible causes.
GL!
WileE7
WileE7
GL!
the codes i got were 67 31 29
E4OD has 19
C6 Does have 17
and by Baumann
its P-R-N-OD-D-1 the first part of my vin is 1FMEU15, will the mlp fix the problem with my engines loss of power when i'm driving
Sorry my friend, it won't have OD if it is a C6
ck the diagrams Chris has @ his site to confirm what tranny it is; code 67 is da thang to fix; will look at all your posts again to see if i can figure this out ad will try to reply again soon; have a lot of work coming in this week.
31 PFE or EVP circuit below minimum voltage of 0.24 volts, etc.
29 Insufficient input from vehicle speed sensor
ck for bad connection/ frayed/broken wirng at VSS connector;
Symptoms may include:
loss of anti-lock brakes
the "anti-lock" or "brake" warning lamps on the dash may be lit
RPM limiter may be decreased
automatic transmission shifting may become erratic
other symptoms may also be present
If you need to find the VSS sensor, look here under Electrical; Sensor,
http://home.comcast.net/~miesk5/BroncoTech...ctrical..Sensor, VSS....
(EVP (EGR Valve Position) or PFE (Pressure Feedback EGR) sensor voltage too low, or EVR (EGR Vacuum Regulator) circuit problems)
here it is http://fordfuelinjection.com/images/egr01.jpg
"This sensor mounted to the Exhaust Gas Recirculation Valve (EGR) monitors its position. The computer delivers less fuel and more spark timing when the EGR is open. Lowering fuel millage and tail pipe emissions. " thanks to Ryan!
EGR Valve Position (EVP) Sensor & EGR Vacuum Regulator Solenoid (EVR) Testing by Dustin S
http://ylobronc.users.superford.org/documents/egr/
EGR Valve Position (EVP) Sensor Operation & Testing, Ford by tomco-inc.com
http://www.tomco-inc.com/Tech_Tips/ttt19.pdf
On Fords with computer controls, the EGR is electronically controlled
and there is an EGR Valve Position (EVP) sensor attached to the top of
the EGR valve. The most important thing to remember about these
systems is that the computer relies on the EVP sensor for more than
EGR flow. It uses the sensor input to compute timing advance and
injector pulse width. Check the EVP sensor in much the same way you
check a throttle position sensor using a DVOM or, better yet, a
labscope. If it is defective, replace the EVP sensor and EGR valve
together to prevent inaccurate signal voltages.
The Ford pressure feedback electronic (PFE) system monitors exhaust
backpressure and sends a 3-5V signal to the PCM. (Less than three
volts would indicate a vacuum in the exhaust system­a rather
unlikely prospect.) At idle it should be 3.0 volts and at maximum
backpressure, almost 5.0 volts. High readings at idle indicate an
exhaust restriction, low readings an exhaust leak. The backpressure
hose on these systems has been known to clog up from carbon and
condensation, which can be a diagnostic devil if it turns to ice in
the winter. If you must replace the hose, do not use regular vacuum
hose. It must be able to withstand the high heat. by buddy, Bob!
so, ck for a possible open or a short to gnd
& there is a GREAT chance there is a large amount of carbon that restricts the EGR valve passages as well as da idle control valve, & ck for crap stuck between the pintle valve & EGR valve seat
btw this is a neat product!
EGR Tube Screen for 84-96 (a product, but should be considered; see above Carbon Filter for more info & tips) by tomco-inc
http://www.tomco-inc.com/Catalog/m1667t.pdf
DPFE (Differential Pressure Feedback) sensor test and info by smpcorp
http://web.archive.org/web/20040610225422/...view/tt2q00.pdf
WileE7
WileE7
i changed the egr sensor and i get the same codes 67 31 29 rear antilock light comes on when start the truck and sometimes it stay's on and sometimes it doesn't my truck does have problems shifting if i don't step on the gas lightly it and try to drive it like normal it jerks and hessitates or won't shift right even when i try to manual shift it do you think i need to do anything mechanicaly like change my torque converter and transmission or do you think its all electrical i have over 186,000 on the transmission
yo!
it's not the EGR Sensor; code shows it is that little bastadh EGR Valve Position (EVP) Sensor mounted to da EGR Sensor
looks like this http://fordfuelinjection.com/images/egr01.jpg
Ck out the VSS sensor before you spend $2 to $5 k on another tranny and TC
btw, who told you the TC is bad and maybe said the tranny was bad?
Is this person a mechanic?
WileE7
WileE7
yo!
it was one of the guys i work with he works at the auto shop on base but he said he didn't know alot about transmissisons he said i should look into it thats why i came this site to find out what to do he drove it and told me he thought my torque converter was bad. i drove it for a longer distance yesterday but i couldn't get it over 45mph i'm praying that it is something electrical because it ran like a champ up until a month ago
ok
"something electrical" = VSS; a simple fix
here are more symptoms of a bad VSS Sensor:Harsh engagements
firm shift feel
abnormal shift schedule
unexpected downshift may occur at close throttle
Torque converter clutch will not engage
does your speedometer go hay wire too?
here is the VSS Sensor location;
Sensor, VSS Location pics in a 90 by BlueBeast
http://www.supermotors.net/getfile/231830/...-sensor-003.jpg
GL!
WileE7
WileE7
ok
firm shift feel
GL!
the speedometer works fine
Motormouth2025
