wolf83
i measured everything... here are the dimensions ...
starter cone - 4 1/8 in diameter
hole for starter cone - 4 1/8 in diamter
width of starter teeth - 3/8 in (front to back - not tip to valley)
width of flexplate teeth - 3/8 in (front to back - not tip to valley)
flexplate teeth are 1 1/2 in from driver side edge of hole to tip of teeth (1 1/4 in to valley of teeth)
flexplate is 1/2 in from front of tans
starter teeth can travel along its shaft an additional 1 1/4 in.
i wonder if the starter's cone is too long. it might be completely missing the ring gear.
also, i threaded one of the bolts that holds the starter all the way into its place, and it wiggles a bit. i might also have the wrong size bolt.
is it US or metric?
W.
is it US or metric?
W.
