351w in 79bronco
walktall99
I have a 79 Bronco. I'm installing a 96 351w engine. I need to know what motor mounts and headers to use since no information is available for this setup.
I would appreciate any help.
If you previously had a 302 in it, then the mounts are the same. I'll let someone who has a 79 answer the other question.
79bigbronco
Calgary, Alberta, Canada
we put a 85 351w in a 78 chassis, used 85 bronco smallblock mounts, smallblock c6 trans, on stock mount, 80's 351 shorty headers, all bolted up with no modification, hope this helps, pm me if you require additional info
W
walktall99
do you already have a smallblock tranny in the 79?
26673[/snapback]
I HAVE A SMALLBLOCK TRANS...........THE TRUCK HAS THE 351M TRANS
RTM
The 351M/400 are big block trannys. The 289, 302 and 351W are small blocks.
drubbz
