351 Windsor **
Ligon
Looking at getting another 351W for my bronco. The one I have is cracked which it was supposed to be in good working order go figure :angry: . My question is on the ** I was told it is running a bigger cam is this true. I have a lunati voodoo cam that I'd like to put in it and replace the lifters and valves springs if I need to. Just trying to get some information on this. Looking at getting the long block which comes with the heads. Any info appreciated. Not a gas motor guy now if it were about cummins I'd be alright.
L
Ligon
Thanks Justshootme, but I'm trying to find out like internal specs. Trying to see if the cam package in the ** is worth changing out with the Lunati cam kit I have. Thanks.
BB33's
Rancho Cucamonga CA
As far as I know the H.O. is nother more than a four barrel carb and intake manifold instead of the crappy two barrel set up
L
Ligon
Alright thanks for the info buds. Looks like I'll be puttin the cam kit in then. Hopefully that is when I get the motor. :wacko:
I don't have the stock cam specs riht at hand (would have to look them up in a manual) but if you know the specs of the Lunati VooDoo cam, you can compare it to other brands like EdelBrock or Crane that are listed for the 351W ** in Summit or JEG's. They might even list a part number for the Lunati. I also was going to put a different cam in the 351W ** longblock kit when I picked it up, but felt that the stock cam was sufficient. IT was, for a NAPA crappa motor that lasted 3 years/ 20K miles. JSM84
Virgil3rd
