350? 1986 FULL SIZE Bronco
Micah_86
Ok I live in Ft Worth Texas!!!! Gas is now $1.95 around here!!! Anyways, I was wondering if anyone knows where i could find a new motor, I have a 302 right now and I want more power and what not. Where can I find them? And how much, OR what can i do?
Thanks,
Micah
It depends on how much you want to spend. A 351W ** will cost you any where form abour $1,600.00 to $5,000.00 plus from an engine shop. For example http://www.enginesdepot.com/categories.asp...&y=1986&l=5%2E8
http://www.fordcobraengines.com/index.html
That's just a couple of examples. Go to http://www.dogpile.com and do a search on "Ford crate engines" without the quotes. On the lowend you have to supply a lot of the external stuff like alternator,plugs wires ignition, etc. and on the high end you basically just drop it in.
The other option is to find one in a junkyard and rebuild it yourself, kit around $2,000.00 plus for a good one or rebuild your 302. It isn't a shabby engine to rebuild.
Goood luck on your choice,
Virgil3rd
