33s on stock 10 hole rims
hammer down bronco
pa.
i have a 94 with 351 im wondering if i can put 33/12.50-15s on my stock wheels, what i am worried about is it rubbing in the fender when i turn should i do a little fender triming before i go to get the tires put on b.c it looks like they will rub? they are hankook dyna pro mtr03s
tship87
Maryland
Stock wheels I think are 15 x 8. When I bought my 33 x 12.50 tires I had to buy wider wheels so the tires wouldn't balloon outwards. 15 x 10 wheels should work fine. As for the rubbing, I had to space my front bumper out some so my tires wouldn't rub. However, I do have a 4 inch lift on mine so I have no problem with them rubbing on the fender.
wileec
Erie CO
Stock wheels on yours are 7.5 a little narrow but manageable lower the air pressure to keep ware good. Should be good on the fenders but as was said the bumper may be an issue. some space it forward an inch. I trimmed the back corners on the inside it was not noticeable and was real easy. I would not go to 10" wheels if you are going to do a lot of wheeling where you will air down it would be harder to hold the bead. 8s would be fine.
Bronc094
