1996 Ford Bronco E4OD Trans Cooler Lines
LogansLost
Where would be a good place to look for a set of pre-bent replacement oil cooler lines for a 96 Bronco with E4OD trans? Jeff's Bronco Graveyard and I think LMC or somebody had them too but they where for a a different year or transmission or something. Bronco Graveyard had a set of stainless lines for an E4OD trans but for a 97 F-350? So I don't know if those would work. Are these lines something that I'm going to have to take somewhere and have a set bent up? My lines right now look really bad and I'm going to have the whole exhaust out making it really easy to take out and replace myself now before anything rusts through and starts leaking.
yo LL
They are EX to find in a yard.
Any Bronco or F that had the E4OD and prob 4R w/tow package will have what you need.
or cut the hard line and slip rubber line over it w/clamps on both sides. It's not a really high pressure so nothing to worry about. If you're really stuck and want hard lines and don't want to get them from a dealer most shops that do custom brake lines can create some lines for you; or buy the lines and buy a flare kit and bender kit if they charge too much $; Justshootme has a great article on this:
Double Flare Fabrication in an 84 Source: by justshootme84
lastly; you can buy a cooler kit and bypass the oem cooler or replace it;
Cooler & Remote Spin-On Filter (Hayden) Installation in a 96 Source: by David C
Virgil3rd
