1996 Bronco oem spare tire rack
Rano
I have a 1996 Ford Bronco XLT that the previous owner took off and discarded the complete tire rack (everything). I was told that the 1987 thru 1996 are all interchangeable, is this true? When I look in the book show the latch that is still available is listed for 1992 to 1996. I have a chance to buy one off of a 1990. I do not care if it is the same as the one shipped with truck just that it will funtion properly.
AdamDude04
As far as I know.. They are interchangable. If the rack itself goes back to the 80's..there would be no need for a change for the locking peice I would think
If anything buy the one off the 1990. It's what..5 bucks?
Swingaway Tire Carrier (Type 3)
The label in the diagram is wrong. This type was used from '90-96. But since 95 buckin bronco got it on ok,,,
Service replacement EB tire cover: F4TZ-9845026-AAC
This style of spare mount requires a locking lug key (part of #6) as shown here
http://www.supermotors.net/getfile/544845/thumbnail/luglock.jpg
TSB 90-07-13
Publication Date: March 28, 1990
LIGHT TRUCK: 1990 BRONCO
ISSUE: High latching and operating efforts of the swing-away spare tire carrier may be caused by a lack of lubrication on the latch and striker assemblies.
ACTION: Lubricate the swing-away spare tire carrier latch and striker assemblies. Refer to the following procedure for service details.
SERVICE PROCEDURE
1. Make sure the spare tire carrier is latched. Both the primary and secondary latches must be engaged.
2. Spray multi-purpose grease (D7AZ-19584-AA) onto the latch mechanism located on the vertical bar of the swing-away carrier.
3. Make sure the tailgate striker is in the full up position and square. Do not allow striker misalignment.
4. Close the carrier.
* Both the primary and secondary positions must be latched.
* If the carrier does not latch, re-adjust the tailgate striker as required.
5. Lubricate the roll pin on the striker and the portion of the striker which engages the rubber sleeve on the carrier.
PART NUMBER PART NAME
D7AZ-19584-AA Multi-Purpose Grease
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under Basic Warranty Coverage
OPERATION DESCRIPTION TIME
900713A Lubricate Tire Carrier 0.4 Hr.
all by Ford via Steve
