1995 or 96 Bronco Electrical Schematics
alamobronco
Have an intermittent A/C issue involving compressor clutch cycling off and on. Checked the refer charge and it is in spec. I have a Haynes tech manual, but it doesn't match the wire color codes. Can someone offer any hints to fixing my problem and maybe some wiring diagrams.
I replaced the cycling switch and that solved my problem. Most shops will tell you that comes from low refrigerant level. But I go through a couple switches each summer on my work trucks. JSM84
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
942
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
Virgil3rd
