1995 Bronco 5.0 engine dies when put in drive works in 1st and 2nd
DALERECHSTEINER
Hello
I just bought a used 95 Bronco
It drove home fine
now when my son puts in drive it dies 1st and 2nd and reversre works drive will not
What should we look for
Dale
Thank You
yo Dale,
WELCOME!
Sorry to hear about your Bronco.
fyi 95 Bronco-F-Series Workshop Manual by Ford
https://www.motorcraftservice.com/pubs/content/~WSSJ/~MUS~LEN/20/SSJMAIN.HTM
go to Section 07-01A:
https://www.motorcraftservice.com/pubs/content/~WSSJ/~MUS~LEN/24/SSJS71AL.HTM
Transmission, Automatic, E4OD
 Read through various sections such as:
Transmission Fluid Level Check
Transmission Fluid Condition Check
 etc.
and esp.
Diagnosis by Symptom Routines
https://www.motorcraftservice.com/pubs/content/~WSSJ/~MUS~LEN/20/SSJ71A11.HTM
pick out the Symptom(s) such as;
Engagement Concerns
No Forward Only
Shift Concerns
No First Gear in Drive, Engages in a Higher Gear
Note that the first test for 215 — ELECTRICAL ROUTINE is Run On-Board Diagnostics;
This is also ref to as a DIY Self Test for Diagnostic Trouble Codes (DTC)s
Try the self test by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?&pid=74587&mode=threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.
And Post em here according to:
KOEO
KOER
Virgil3rd
