1994 Bronco fuel gauge problems
black85gt
Millersville PA
Hey guys I'm having some problems with my fuel gauge. When the tank gets low the gauge jumps all over the place and won't give an accurate reading. I know my stang g=has an anti slosh module on the back of the cluster but I can't find any info about one on the Bronco. Any idea what they call it or if their is another problem? Thanks in advance.
BroncoJoe19
The sender unit is a variable resistor/potentiometer type. That section is probably getting flaky. PRobably have to change it out. IT will require dropping the tank or cutting an access panel to do so.
black85gt
Millersville PA
I took the tank out of my old 85 several times. I was hoping that wasn't the case. Cutting an access hole sounds like a mighty fine idea.
Virgil3rd
