Whipsaw
- Joined
- Nov 26, 2016
- Messages
- 63
- Reaction score
- 51
HI Everyone,
I am tooling up to embark on a front end rebuild as the bearings are starting to hum. I would like to replace all the bearings and seals, though the Ford shop manual I have doesn't specify the part numbers for all of the seals. The diagram break out listings just say 'seal' with no part number. Sourcing through RockAuto, trying to stay with Timken bearings and seals. So far, I've identified:
Bearings
TIMKEN SET 37 Front inner automatic locking hubs bearing and race set
TIMKEN SET 45 Front outer automatic locking hubs bearing and race set
TIMKEN SBK4 Front Optional Kit = Bearing B2110, Seals 722108, 722109 and Ring Bearings & Seal kit
Spindle Hub Seal
National 710453 Front Inner (there is also a TIMKEN 4250 Front inner, looks different- should be 'wheel seal 1175' from the diagram)
National 710455 Front Outer
According to the diagram, there is a large seal for the shaft assembly between it and the spindle with no part number (go to the dealer?).
I feel like I'm missing something... also, another thread mentioned being prepared to replace the seals at the differential housing due to pulling the axle shafts.
Thanks for help and insights, this is a big job; will likely replace u-joints too.
Bearings
Spindle Hub Seal
