1993 5.8 fuel filter help
wsmc923
I just picked up an 1993 EB and am doing the normal tune up things. I can't seem to figure how to get this fuel filter off. It has braided lines going into it, and both types of disconnects I have tried to use don't seem to work. Any ideas?
blkwlf
it requires a little specialty plastic tool
you can go to most any parts store and get the tool, just ask for a (snap on) fuel line tool. its easy ton use and cheap. you might even be able to have them show you how to use it.
yo!
Fuel Filter Replacement also relevant to later model Broncos by FordMan at fordf150.net
http://www.fordf150.net/howto/fuelfilter.php
Do it only on a COLD engine with no electric sources close-by (esp a heater or someone smoking)
watch your eyes, fuel pressure may give you a bath... some like to relieve pressure by opening the Schader Valve on the fuel rail, but I just let it drip on a plastic pan and rags under da filter.
btw, looks as if you're missing 2 safety clips on the line; should have em in new filter box or go back and buy em.
GL!
wsmc923
wsmc923
Thanks a ton. I think I need to go get some penetrator or something to loosen up the springs. Have a feeling that this is the origional filter on here, and that there is 14 years of gunk built up around the springs in the lines!
Lana Kane
