1991 Eddie B. Need some help
Bigmac
1991 Ford Bronco
V8 Four Wheel Drive Automatic 78,000 miles
I took my truck a little offroading, truck seams to be in four wheel drive but i don't think it is. The truck will not go anywhere in reverse and it seams that it is in reverse and drive at the same time. when you hit the gas peddle while in reverse it lunges forward a sec, like it wants to go forward and not back but still will not go anywhere. The truck will go forward but have to hit the gas more like when you are in 4x4. to give you a visual when you are in reverse is like you are slamming on the brakes while on the gas. also will not go anywhere(at least back in driveway so can't see forward) in neutral so i hope someone can help me.
Krafty
Ontario Canada
did these reverse/ no reverse problems only start when you went off roading? is it only when you are in 4x4?
Oldhenry1
