1987 bronco 2 sputters when not accelerating
rich87bronco2
I recently found a 1987 Bronco 2 that is in great shape. Beautifully maintained but after I get up to speed and I'm just maintaining a constant speed, it starts to kinda sputter or skip. when i apply the gas it will stop the sputtering. Really only does it at speed over 50 mph.. Any ideas on the cause?? thanks
Rons beast
Hey Rich,
Welcome.
What are your vitals on the truck? Engine size, man or auto, Fi or carb? When was the last tune?
You may have a carb problem if you are running a carb. ( I don't know the specs off the top of my head like some guys on here) Fuel delivery is my first thought. Clogged fuel filter.
Usually when the ignition system is breaking down, it's under load. That would mean that your would get the sputter when you try to accelerate. Sounds like that is not the case.
On any new (new to me) vehicle I get I do a basic check of the timing, filters, fluids, vacuum lines, cooling and charging system.
That said It sounds like you should check the fuel filter first.
Good Luck
yo Rich,
WELCOME!
What engine and trans is in there?
If fuel injected:
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/page__pid__74587__mode__threaded
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.
And Post em here according to:
KOEO
KOER
R
rich87bronco2
2.9 v-6 fuel injected, auto trans, 4x4.. previous owner thinks clogged injector. it was very well kept but sat for about a month before i bought it. i've had it for 3 weeks. I want to thank you guys for responding to my question. I have to try and get this worked out on pretty much a ZERO budget
Rons beast
Hey Rich,
"I get up to speed and I'm just maintaining a constant speed, it starts to kinda sputter or skip. when i apply the gas it will stop the sputtering. Really only does it at speed over 50 mph.."
That doesn't sound like a clogged injector. If one were clogged it would be clogged all the time, and your symptoms would be present at all engine speeds.
Do the checks like M5 suggested. I'm still leaning toward a fuel filter. especially since you said it had been sitting.
Good Luck
Sufferedformula
