Well if you built that car you will have no problems . Take the drive shafts off / unbolt the T Case and remove / Take inspection cover off bellhousing / remove starter / Take 4 nuts off torque convertor if auto / Take out 6 bellhousing bolts / Remove 2 bolts that hold tranny mount to tranny and jack tranny up slightly / Remove cross member there are a couple different kinds . / Let tranny down and wiggle out . Thats about it other than a couple wires to the T case and tranny and the speedo cable .
/emoticons/
[email protected] 2x" width="20" height="20" />
