Keithkos92
- Joined
- Dec 9, 2019
- Messages
- 13
- Reaction score
- 0
Yo Keith,Off topic but does anyone know what size bolts these are or if these are a special bolt. It’s what bolts the yoke off the transfer case to the driveshaft
Driveshafts & U-joints IF THE IMAGE IS TOO SMALL, click it. To check u-joints while the d'shaft is installed, set the e-brake, shift to N, and see how far you can rotate the t-case output back&forth WITHOUT moving the rear axle yoke/companion ******. Also see how far up&down you can push the d'shaft. Less is better. 1 Nut 382836-S100 Tighten to 11-20 N-m (8-15 lb-ft) 2 Universal Joint 4635 (Type 1330 in most Bronco rear driveshafts: 3 5/8" x 1 1/16") 3 Snap Ring (Part of 4635) 4 Bearing Cup (Part of 4635) 5 Seal (Part of 4635) 6 Trunnion (Part of 4635), aka "spider", "cross" A Needle Rollers (Part of 4635) B ****** Washer (Part of 4635) C Bearing surface (Part of 4635) 7 Driveshaft 4602 8 Pinion Nut 375646-S2 Tighten to 0.9-1.5 N-m (8-14 lb-in) preload rotating torque (used bearings) or 1.8-3.3 N-m (16-29 lb-in) new bearings. 9 U-Bolt 386867-S 10 Rear Axle Universal Joint Yoke (Half-Round) 4851 11 Dust Seal 4859 12 Driveshaft Slip Yoke 4841 13 Counter Bore/Pilot (Part of 4841) 14 Driveshaft Rear Axle Companion ****** 4851 15 Driveshaft ****** Yoke 4866 ![]() 17 Double Cardan Assembly 4635 18 Slip Yoke Boot 4421 19 Driveshaft Center Yoke 4784 20 Driveshaft Centering Socket Yoke 4782 CarQuest (Dana/Spicer/Perfect Circle) PN 9109/7-0079 ~$30 21 Centering Spring (Part of 4782) 22 Transfer Case Yoke (******) 7B214 23 Bolt, Tighten to 27-38 N-m (20-28 lb-ft) |
