1996 bronco auto. hub issue.
dennis93mustang
hey i just picked up a 96 bronco (always wanted one) anyway the 4x4 on the fly works fine buttt my automatic locking hubs are not locking when i shift into 4wheel or 4 low. so i was looking online and found that alot of people just swap em out to manual locking hubs which i prefer anyway. i was just wondering what ones are the best and easiest to install and prefer a decent price? all info is appreciated.
thanks
50joe
Trenton NJ
Warn makes a pretty descent hub kit, and its pretty easy to install too. Bronco graveyard sells them. Way better off then those auto hubs. Never seem to hold up.
Krafty
Ontario Canada
Yeah I put warn hubs in my bronco years before I sold it. Im going to be putting the warns into my F150 before the snow flies. they are ultra easy to put in, ultra tough and last a very long time.
5.0 fever
Grand Rapids, Mi
OK, so it does not matter which brand you get, as long as it has a good warranty. But, excuse me I'm new to the whole prospect of hubs, can you maintain the "shift on the fly" with locking hubs? I live in Snow Country (Michigan) and it is nice option to have if you are sliding around, just hit the button. My hubs are currently working fine. I had a friend tell me that since I do not use the 4 wheel in the summer I have to engage them once a month to make sure they do not sieze up. So that is what I do. I know sooner or later I will have to swap them out and wanted to make sure I keep the "fly" option.
wileec
Erie CO
In the winter I generally keep my hubs locked. I do not have push button but the idea is the same. Just lock them when the snow starts flying and use as needed.
D
dennis93mustang
I know it is the hubs that are the problem i put a mark on the driveshaft and the front axle and engaged the 4x4 then moved the truck and both were moved i then disengaged the 4x4 and moved back to where the truck originaly started and the marks did not move back, that tells me it is working fine, i then engaged it once more and jacked up one fron wheel at a time and tried to spin them, each spun freely front and back that tells me the hubs are not engaged. now what is this that your saying about "old-style wheel bearing adjusting nuts"? why would i need them? and do i def. need them?
thanks guys
D
dennis93mustang
i will try again but i dont think thats it...what about the big hex nut? y would that need to be replaced along with the manual hub?
ford_302
canby, OR
dennis93, are there 3 or 5 screws on your auto hub? if its 5 then all you need is the new hub.
