i need help on a 3rd member rebuild
zintrex
hi.
in a couple of days my new differential will arrive,
but i dont have a rebuild manual,
so do any of you have the torqe specs on the bolts ?
also any of you have the backlash tolerances or what its called
i think its between 8 to 15 thousands (saw that in a vid on youtube)
preferably in metric value but i can do the math on american values too
also thanks for having the patience w my typos and shit.
i may not be the best writer but im a devil w the velder....
Z
zintrex
YO!I capice that English is your not your native languge. You are rebuilding a Ford 9" differential, correct?
If so;
9" Rebuild-Gear Setup by OX1 http://www.ford-trucks.com/articles/9inch/index.php
Trac-Lok™ Parts Break-Out Diagram in 78-79 w/ Nomenclature
Source: by Ford via broncograveyard.com http://broncograveyard.com/dia/7/fo9diatraclok.jpg
Did you use this Video?
Backlash Adjustment Video
Source: by Kenneth C (badshoeproductions) at youtube.com
Thanks a lot for the help!!
i got the rear axle rebuilt now.
i got me a ok deal on a standard carrier w a spool pre installed, so im gonna use that one until i can afford to swap it for a air locker.
