Running the beach
hammer down bronco
pa.
Anyone have tips about running on the beach or dunes? i no to air down the tires but does anyone do anything more on their bronco? and how much air would you recomend leaving in the tires for 31/10.50s and 34/10.50s?
Thanks in advanced for any replies
Cocobum
Florida
Don't go past the seaweed, its the tidal zone and you will be screwed if you get stuck there. Also if possible make sure its not going to be a full moon or new moon as these are the highest tides. Besides that its just like driving on lose sand.
H
hammer down bronco
pa.
Thanks guys i no to keep an eye on the temps and i will probably get a trans temp gauge anyone know where i can get a cheap one with a mount?
yo for 31's I used 20-25 psi; the 20 psi for when going on the beach and satying there and the 25 when I woud return to pavement for supplies/food when staying out all day and part of the night.
here is pretty good article on sand runs http://www.dirtopia.com/wiki/How_to_Drive_in_the_Sand
Some go lower since they have on-board air (OBA) or have anir tank or an on-beach source such as what used to be at our local surf fishing state beach park. The ex ousted Gov had them removed to save $.. but state forgot to tell anyone it was disco'ed...
and for a 93 bronco build-up; they went down to 25 & 9 psi for **** Cepek Mud Country
35's
http://www.off-roadweb.com/tech/0809or_199...onco/index.html
I thought there was another thread about driving on the beach? I often go down here, since I'm only a few miles from the coast. The difference in driving technique is going to be in packed, hard sand or loose, soft sand. Hard packed sand or just after a rain, I don't even air down, and have seen cars on the beach, bascially, no problem and just like driving on dirt or gravel. The tough one is loose, soft sand, where you can easily dig holes with your ties and high-center. I've seen trucks go ten feet and get buried.
If your local beach allows it, try to drive close to the tide line or that seaweed line, since the sand will be wetter and more compact. Some beaches don't allow that, since it supposedly kills little critters in the sand when you drive over them. you'll have to watch out for debris left during the high tide, too, but I can usually run 20 mph along this zone.
The key in soft sand is a light, steady throttle. IF you hammer down like driving thru mud, you'll often break thru and dig a hole. The rear wheels will tend to bounce or "chatter", and this can break a shock real easy. If you're stopped, take off slow and easy until you get some speed going, maybe 5-10 mph. I don't air down very often, but would keep at least 20 psi if you have to travel on the tarmack before airing back up. I carry a small shovel to dig out from getting bured whenever that does happen, rather than using a board under the tire for traction. JSM84
H
hammer down bronco
pa.
Thanks jsm84 i couldent find another topic about this type of off roading in about 8 pages so i just decided to ask some questions my self! the beach that i will be going on is super loose sand so i have to air down but its not a problem because they have air stations right off the beach, just this weekend there was an s-10 blazer on 31s and he didnt air down and went into the sand and got about 20 feet before my friend had to tow him out. so i do have some idea of driving on the beach just not in my bronco so i wanted to learn how they handle and how i need to handle it which i have accomplished with all the tips you guys have given me. But if you are in 2 wheel and burie your back tires to where they cant get you out can 4 low pull you out?
As long as you're not high-centered, where part of the frame or axle is on the ground, eve n4Hi may pull you out. Usingn the shovel to dig the sand away from the front of the stuck rear tires will help, too, so you're not pulling so much against a wall or lip of the hole you've dug with the tires.
If you take it slow and easy at first, until you get used to how the Bronco handles on soft sand in 4Hi, you should be good unless you hit a really rough spot. IF there's much traffic on the beach, and some yahoo has done donuts across the road, you'll have the most problem when trying to cross those ruts.
worldclass
Even if you hit some super soft sand, as long as you are aired down, you can put it in 4 high and should have no problems. If you feel your tires starting to dig, and not get out of the spot your in, stop!! Put it in 4 wheel and try again, and if that doesnt work, then go to 4 low.
If you are aired down, and watch for witches eyes in the sand, and watch your temperatures you'll have no problems
Oh and one more thing, STAY OUT OF THE SALT WATER!!!!!
15 lbs of pressure will get you in and out of anything you will come across
worldclass
I just realized you are probably not riding in the dunes so you shouldnt have any problems with em, but it is where wind has swirled sand in the shape of a "witch's eye" and its like hitting a wall. People die in them every year.
But like I said if you arent riding in the dunes you dont need to worry about them
H
hammer down bronco
pa.
ok im not really gonna be in the dunes but that sounds pretty serious how deep are they usualy?
Where are you going to? Long Beach Island or down South?
Island Beach State Park - Mobile Sport Fishing Vehicle permits to operate 4-wheel drive vehicles on the fishing beaches may be obtained at the Park's Visitor Contact Station at the entrance gate.
MANDATORY EQUIPMENT FOR A MOBILE SPORTFISHING VEHICLE (MSFV)
Permits are issued to 4-wheel drive vehicle owners for fishing purposes only. Carrying the basic equipment listed is required whenever the MSFV in on the beach.
1) Fishing equipment and bait and tackle for each person over 12 years of age;
2) Tire gauge;
3) Spare tire;
4) Workable jack and board/support for jack in sand (3/4 in. x 12 x 12 in. plywood square minimum size) I always have about 4 pieces plus some tarp to help keep sand out of the area while digging.
5) Tow chain or ****** line;
6) Shovel;
7) Flashlight;
8) Fire extinguisher;
9) Auto first aid kit;
10) Litter/trash bag;
11) Minimum of 1/4 tank of fuel.
A current tide chart is highly recommended. Jumper cables for the vehicle's specific battery type are also recommended.
H
hammer down bronco
pa.
i will mostly be going to assateuge island in ocean city md. and who knows maybe some other beaches and islands
