need a 302 expert
built5.0
1992 ford bronco 302
automatic
265000 miles original motor
problem:
starts and drives but smokes bad , smoke smells like gas im pretty sure, shakes and makes noises, has oil or some kind of black residue coming from the driver side exhaust manifold. loss of power.
what i did:
checked timing and adjustd it, didnt change.
pulled all spark plugs and wires and replaced, didnt change
ran obd1 scanner
got codes such as cannot control cylinder balance
egr bad flow
oil and antifreeze not mixing at all or low
any ideas on where to start again im stumped?
its not really knocking like it threw a rod either
Bronc76
if you have all them symptoms and that many miles i would say its time for a rebuild.
Bronc76
Yeah, i didnt either, but with two cracked pistons, blue smoke, and losing oil pressure, I had no choice :lol:
fordsohc46
fordsohc46
searcy, arkansas
i would check compression at least on bank 2. should be 120psi+ on all cyl. also try hitting egr valve with hammer it could be stuck but like bronc76 said you probably need an overhaul.
1992 ford bronco 302automatic
problem:
what i did:
ran obd1 scanner
egr bad flow
The smoke that smells like gas is probably from running too rich. Does the choke open up as it warms up? How old is the carb? You may need to rebuild it, but a new one will work out better.
The same for the residue on the driver side manifold. If it is not oil then you probably need a new manifold gasket. If it is oil then the valve cover probably needs a new gasket.
built5.0
this truck is not carberated it is fuel injected it is a 92?????????
92bronco_in_progress
Yeah its a 92 bronco
Waretown, New Jersey
check your compression, egr valve, fuel injectors, cat converter, TPS. my guess is your rings might be bad which would explain the oil....it may be time for a rebuild, but you might get lucky
