crank and waterpump v belt pulleys
71broncrollsport
What pulleys do you guys run on your broncos that didnt come with ps i need some pulleys for my 71 i need a double pulley for my water pump and crank. what can i get them off of
Bronc76
check out bcbroncos.com, i think they have the double pulley you're looking for
71broncrollsport
what car(s) can i get a double groove water pump pulley and double groove crank pulley from for my power steering conversion. I was told to use 2 belts on that goes crank to water pump to alternator. And crank to water pump to ps pump. They cant be much more than 6 and a quarter inches
On my engine I have one from the crank to water pump to PS pump and one from the crank to alternator.
"What pulleys do you guys run on your broncos that didnt come with ps i need some pulleys for my 71 i need a double pulley for my water pump and crank. what can i get them off of?"
Ideally;
-crank pully 2 grove., 3 bolt., 6" OD
-W/P pully 2 grove., 4 bolt., 5 11/16" OD
Most SB Fords would have these I would think..........
