Tailgate
fizz
Indiana
The window wont go down so i cant get to the handle. Ive tried from the inside but no luck either what could be the problem if anyone has any ideas i would love too have thrm right now thanks.
oktogo
york sc
there's 3 posible problems
1. the wireing is bad and needs new harness to find it check moter with volt meater
2.the gear is bad does it make grinding when you turn the key?
3. the swtch is bad and it not letting power to the moter
little tip the tailgate may not be closed all the way and its not letting it go down try pshing on it
F
fizz
Indiana
when i put the key in the tailgate nothing happens at all. I looked at the handle and its kinda lifted up and wont budge anymore.
oktogo
york sc
push the handle back down and also check your fuses (2) the big metal ones they may be bad can get at auto store for 4$ each now it nothen happen when you turn key then number 2 is out of the way the gear is fine does switch up front work? try testing with volt meater to see if u get current if not get new one from broncograveyard.com
if you need any more hep just ask o and the moter may be bad to
Shadow_D
Schenectady, NY
First thing is this... Do a search here on the forum, this topic has been covered many times.
Now on to your problem...
You will want to pick a good day or two for this. Take the cover (access panel) off so you can get to the motor. Next get two lengths of wire long enough to go from the battery to the tailgate leaving you enough to work with. You will use these to test / operate the window motor. With the wires connected to the battery and the factory wires removed from the window motor, connect the wires to the motor. If nothing happens, reverse the wires. The window should go down but if NOTHING happens you most likely have a bad motor.
Now with the window down a little you should be able to open the tailgate thus giving you more room to inspect everything.
FIRST STEP AT THIS POINT IS TO CHECK THE FUSE! IIRC fuse #12 should be a 25A fuse. Check to be sure power is flowing through that fuse.
Now roll the window up so you can get at everything (TAKE CARE NOT TO LET THE WINDOW GO ALL THE WAY OUT)
With the window up look for the Safety switch on the key switch. There should be 2 wires, 1 should be Red with a yellow stripe and 1 Tan with a black stripe. Use a small piece of wire to connect those wires. Now test the operation of the window with the key.
If nothing happens, use your volt meter to check for power at the Tan with black stripe wire. You should have 12VDC or so at that point.
If you do not have power at that wire, look for the Black wire with a white stripe and check for power there. If you do not have power there move to the wires between the tailgate and the body. The wires have a tendency to break there.
Easiest way to check for power there would be to remove the driver's side tail light, there should be a plug behind the taillight.
Find the Black with White striped wire and check for power at the front side of that plug.
If you still do not have power at that plug, there will be 2 more plugs between the fuse block and the back of the taillight that you should check for power or even corrosion.
That covers the "Hot at all times" circuit.
Now for the keyed circut...
I will assume you have power windows.
If your windows are working properly that says fuse #14 (another 25A fuse) is good.
Now you will want to have a friend to help you with these tests...
With the key on, have a friend push the switch in one direction as you check for power at the tailgate. You will be looking for the Dark Gray with Light Gray stripe and the Pink with Light Gray stripe.
If you have no power at either wire, have your friend push the switch in the opposite direction and check those wires again.
If no power, move to the plug behind the taillight and look for the same wires and again check for power same as above.
Again if no power, check the same plugs under the truck for corrosion / power.
Something to keep in mind... When ever you open a plug, it's always a good idea to put "di-electric" grease into those plugs to help prevent corrosion.
If at this point you still can not get your rear window to work, I'm at a loss because this checks the entire electrical circuit for said window. Maybe someone else can pick up from where I'm leaving off...
younghutch
...little tip the tailgate may not be closed all the way and its not letting it go down try pshing on it
This.
Happened to me last week. Giver 'er a good shove while turning the key. Good luck.
