CRAZY GAS GAUGE
BEEVO
n c
stats
95 eddie bower
5.0
automatic
4x4
i'm new here and have a question?
i've done all the back tracking i can on the sight and came to the conclusion that some where there was a wire grounding out to the sending unit causing the gauge to rise up and down to full then back down to normal reading, but once back tracking i found no breaks unless its on top of the tank. any other conclusion to what might be wrong if there isnt any grounding isues?
white night
coloma MI
stats95 eddie bower
5.0
automatic
4x4
i would pull the gas tank and check the sender and wires if you traced all the wires and have not looked there it has to be there or at the gauge
BEEVO
n c
how would i know if it was the gauge since its easier to check that then dropping the tank.
white night
coloma MI
i would go and buy a cheep one at a parts store and hook it up to see if that works or if you a meter fluke meter you can check for open circuits and open grounds check the ohms that is a start for ya
Good luck :D /emoticons/biggrin@2x.png 2x" width="20" height="20" />
92bronco_in_progress
Yeah its a 92 bronco
Waretown, New Jersey
thats most likely a bad sending unit, i have that problem in my trans am right now....if the contact in that spot is worn out it will read fuller than full
