lots of stuff disconnected, please help.
manny1983
bolingbrook, il
i got this 92 bronco last month, it has a lot of this that arent hooked up to anything and i wanted to see if someone knew where they went. i tried looking in my chilton's manual but i cant seem to find anything. any help is greatly appreciated, thanks.
illinoisbronco
morris, illinois
the thin black tube L shaped goes to the throttle body, the red and black tubes with the black rubber end connects to the thing that looks like a coffee can i dont know what its called but look in chiltons under emissions for a picture of it, the last one circled in red is a pcv valve, looks burned, needs to be replaced for 5 bucks and it goes into the valve cover right under it. feel around, you'll find the hole. the small dryer hose looking thing is just an intake hose on a filter for your thermactor pump. leave it alone its ok like it is just fasten it down. did i miss any? if you want i can walk you through it over the phone. just pm me with your phone number and ill call you and explain exactly what to plug where if you need.
