please help with this code (63)
illinoisbronco
morris, illinois
i did the self test 3 times, all power drains were off, no vacuum leaks, and plenty of antifreeze - but everytime i try to initiate the self test, it will wait about 10 sec. and then flash the code 63, tp circuit below minimum voltage. but it flashes the same code about 6 or 7 times. i dont understand this. am i missing something obvious?? please help if you have an idea
1987 bronco 302,5.0 eddie bouer
i did the self test 3 times, all power drains were off, no vacuum leaks, and plenty of antifreeze - but everytime i try to initiate the self test, it will wait about 10 sec. and then flash the code 63, tp circuit below minimum voltage. but it flashes the same code about 6 or 7 times. i dont understand this. am i missing something obvious?? please help if you have an idea1987 bronco 302,5.0 eddie bouer
yo!
63 (orc*): TP sensor voltage too low. Suspect open TP sensor, harness.
Testing & Operational Description & Parameters (click on Sensors) Source: by Ryan M
more on da TPS in my Bronco site under;
http://www.broncolinks.com/index.php?index=137
also, good job on the diy self test and everthAng else you did!
These links should be helpful.
This one has a drawing of the pinouts for the TPS
http://www.fordfuelinjection.com/?p=30
This thread is a how to pull codes thread, but at post #15 it links to how to change and adjust your TPS.
http://broncozone.com/forums/index.php?s=&...ost&p=74581
If I recall correctly, your TPS should be getting 5 volts from the PCM, and at idle it should send back between 0.5 volts, and 1.0 volts.
IF so, make sure your connections to the TPS are clean, (CRS electronic contact cleaner is a handy dandy for that purpose).
illinoisbronco
illinoisbronco
morris, illinois
thank you gentlemen for your bronco expertise. i cant tell you the problems ive solved by reading you two guys posts. broncozone ought to pay y'all
