changing gears
blackhoss89
Brown Summit , NC
im an ok mechanic and have changed the entire rear axle and done other tasks such as drive shafts but im in a pickle, my truck s right rear tire was catching so i towed it home and removed the rear diff cover to reveal a torn up ring and pinion ,after deciding to embark on this asventure my self i removed the carrier and the pinion so i could replace them, thats where im stuck, i want to replace all the barings also but am having trouble understanding how the pinion berings and the other things in that area go in any pics,diagrams, or kind words are appreciated
muddinlate86
va.beach
what do you mean by"chatering"was the truck jerking or shaking? im having sum what of a sim. problem
Ok, you wanted diagrams so here's the info from the Ford factory manuals. I assume you have an 8.8" rearend. This is what you should need.
Lemme know if you need something more or if these scans don't explain it well enuf. The job itself is fairly straightforward but the real bitch is setting a proper contact pattern so that the ring/pinion combo lasts more tha a few hundred miles. I've seen it done wrong and the whole assembly lasted maybe 600 miles before chewing itself up so badly that neither the ring OR pinion could be salvaged. Get yourself some Prussian Blue and do your homework. If you need the scans for the contact pattern let me know.
blackhoss89
blackhoss89
Brown Summit , NC
Lemme know if you need something more or if these scans don't explain it well enuf. The job itself is fairly straightforward but the real bitch is setting a proper contact pattern so that the ring/pinion combo lasts more tha a few hundred miles. I've seen it done wrong and the whole assembly lasted maybe 600 miles before chewing itself up so badly that neither the ring OR pinion could be salvaged. Get yourself some Prussian Blus and do your homework. If you need the scans for the contact pattern let me know.
thanks bud this should get me started ill let u know if any more help is required
my sound was more of a constant hard click or shudder like some thing was catching
I've seen that. A friend had one with a loud click that you could feel thru the chassis. We eventually narrowediti down to the rearend and when we pulled the center section we found 3 of the ringgear bolts had backed out. One had had the head shaved completely off and the other two were in the process. Apparently the prev owner forgot to loctite those particular bolts when he swapped gears.
stevedave
