Last week, i was driving my bronco home on the way home from purchasing it, and the oil pressure dropped to zero, and the CEL light came on.
The previous owner had installed a 2 pod gauge on the floor, one of which was an oil pressure, so the one on the floor was at zero pressure along with the one in the cluster.
I had it towed and after several tests they decided to pull the motor (partially) and replace the pump, screen, pan and pan rails(rusted). to the price of around $1500. They said the pickup screen was almost totally clogged, and there was alot of crap in the oil. I trust them because they accually showed it to me.
They gave it a thorough test drive before returning it to me, and said everything was fine, but the gauge on the cluster/dash was inaccurate-reading too low, but the mechanical one in the pod was reading just fine.
Today i was driving and now the one in the cluster/dash will go to zero, and the CEL will come on but the one in the pod is reading fine, just as it was. 35-40 at low idle, warm, in gear. as soon as i tap the gas it goes to around 60 or more. but the other gauge will come back every once in a while to L(randomly while driving).
I am not really concerned becuase the motor is running fine, no knocking or anything. The only thing im am concerned with is for some reason i have it in my mind that if the computer thinks there is no oil pressure it will **** the motor eventually, becuase it cant read the mechanical gauge in the pod on the floor just the one on the dash/cluster. I just remember reading that somewhere it will **** itself becuase of no pressure for a period of time. Any ideas? True?
Plus i followed the tube that goes directly into the mechanical gauge to the side of the block and its fine. I cant even find where the one on the dash is hooked up to.
Thanks for reading and helpng me out.
/emoticons/smile@2x.png 2x" width="20" height="20" />
