lowering idle
89eddie89
charlotte nc
So when I have my foot on the brake and I am in drive, I am at about 800-900 rpms.
When I put her in park she raises to about 1200 rpms... And it gets really annoyingly loud when I am waiting in my car...
Tips on the steps to lowering the rpms....
Thanks
:D /emoticons/[email protected] 2x" width="20" height="20" />
Jersey
Thanks
Technically, the idle is computer controlled and not adjustible. If its running that high, check for a vacuum leak somewhere. If you can't hear it, (which would suprise me), take a can of carb cleaner and spray where the intakes meet eachother, lower meets head, and all vacuum lines. The idle will change when you spray where it is leaking.
pinson27
Thanks
Sounds like TPS..(Trottle Position Sensor),it lets the computer know how far open your throttle is.Usually the sympyoms are high idle,up and down idle,dying and decreased gas mileage.The sensor is located in your case,on the bottom side of the throttle body.Its an easy fix,and takes about 20-30 minutes.Be carefull installing the new one and note the position of the old one....they are slightly pre-loaded
Jersey
The TPS does not control Idle speed. The butterflys are fully closed when you are off the accelerator, (supposed to be), and the IAC valve controls the idle. Although a bad TPS will contribute to a rolling Idle, It will not cause a steady high idle. That is only caused by either 1: a vacuum leak 2: some knuckle head messed with the stop ***** on the throttle plate. 3: the IAC valve is sticking or 4: the timing is off.
90-BRONCO325
Warner Robins, Ga.
That reminds me. I had my 90 Bronco worked on and it has always had the check engine light on. The mechanic said he checked the codes and it said Idle Air control valve which was unplugged when I got the truck. When I plug it in, the idle jumps to about 1600 rpm. I went and got another one and installed it but when I plug it in, BOOM 1600 rpm. I have to unplug it to get lower idle. It still idles kind ofhigh. Anyone help me.
Did you see Jersey's post in this thread?
mongo
Royal Oak,Michigan
I know dumb But anyone got a picture of what he is talking about, It sure would help Again I New to Broncos mine is an 1988
Here you go... IAC for a '90 bronco 302...
hope this helps
joe
