need a little help
broncoman90
nanticoke pa
i put an intake set on for the 4th time i cant for the original gaskets at the ends of the intake they worked well but the only ones i can get are cork and so far rtv-black has not sealed it this is driving me insane sorry for it being so long but i have one more problem the truck wont turn over when its hoti replaced every wire and i have replaced the starter and but a wrap on it any help would be greatly appreciated
Did you put RTV in the corners at the end of each cork gasket? There is a spot at each corner that doesn't get covered by a gasket.
terprugr
Havelock, NC
Have you checked the voltage on the battery and amps if you can when it is hot?
broncoman90
nanticoke pa
i tried using cork twice i guess i have bad luck cuz they seem to leak worse i have been trying to find the o.e.m gaskets [rubber] ill probaly have better luck with them
broncoman90
nanticoke pa
if it mattars the battery is only a few weeks old i think its the radiant heat from the manifolds cooking the starter. heat wrap maybe? on the manifold
Roadkill
Killeen, TX
Have you checked or replaced the starter relay when this occurs? Over the years I have seen few that would stop working when its hot in the engine bay and then work again after it cooled down. The relay is about $10 at any auto parts store.
broncoman90
nanticoke pa
i replaced it not to long ago im still thinking its heat but who knows but anyways i would like to thank everybody so far for there help
madmax
quakertown pa
once the truck is hot drive ti up on ramps for better clearance and shut it off, then try to start the truck to make sure it wont start.
then assuming it didnt start take a pair of jumper cables and run the red line from the positive terminal on your battery to a screwdriver and touch the ***** driver to the starter (you will get sparks, dont worry they wont burn you), if it dosent turn over then something is causing your starter to sieze, most likeley heat, try something like this
http://eastwood.resultspage.com/search?p=K...20wrap&rk=8
you should be able to wrap some kind of heat insulation around the starter to keep it from getting as hot, actually painting it with chepo silver paint even helps a little.
also if the starter turns over just fine you could be having problems with the neutral safty switch somehow overheating and screwing up
EDIT
also about the intake try buying gasket paper and making your own gasket, its not that hard to do with a little patience and a razor knife , round holes can easily be made with some small copper plumbing parts used as punches. also try ultra copper if the black isnt handeling the heat, and you are letting the stuff cure without tightenign the bolts down, right?
bidibronco
Norfolk Va
I remember in highschool we never used the front or rear gaskets for the intake. Just a HUGE glob of black rtv stuff. I used the cork when I redid my engine and have a leak on it now so in the upcoming weekes I'll be replacing it, along with the stupid cork oilpan gasket. *should've spent the money for the one piece* *dough! :wacko:
broncoman90
nanticoke pa
EDIT
i have figured out that its the heat from the exhaust so im gonna get wrap and take care of it thanks for the help
broncoman90
nanticoke pa
i refuse to use cork anymore id rather suffer with a little leak like with rtv but i found a company on ebay that sells the rubber end gaskets (thank god)and i ordered them so as soon as i install them ill let everyone no how i make out thanks again
