FRONT DOOR LATCH ISSUES
mobetta
Just bought this original 69 w/ a 302 and three on the tree. 78,000 original miles, was parked (outside) in 1979 and hasn't been run since. I'm going to do a major restoration on it and I'm in the process of ordering a bunch of parts from Bronco Graveyard. HERE'S THE QUESTION: Both from doors on the thing are hard to open. The push buttons go all the way in and don't seem to want to release the catch. After a bit of fiddling they will eventually open. Any suggestions?
muladesigns1
Was Da Bronx now AZ
mine did that as well, try adjusting the rods inside the door, mine were a little bent from all the years of use. grease everything will molly **** and you should be fine
bigbluebronc
ca
I would give it a quick flip! and make some $$$ or spend 3-7 grand and make it a wheeler or pristine...........I would cut it up and wheel till there was no more metal left (i try too bend the metal but i cant) its too tall haha
dewshan
amarillo tx
What kind of animal is that on the door? A jackalope?
I would keep that it looks sharp.
Bronco_Betty
SW USA
Mobetta, were you able to fix your door latch problem? If so, care to lend some tips? My driver's side just started doing the same thing,...I greased the linkages, and that worked until I closed up the door panel...man, she's a fickle old gal. I really don't want to tear the whole mechanism apart.
rodsteal
Orange County, CA
If its an original 77 that means no one has screwed it up too bad and good for you. I wish I could say the same about mine. If your going to do a real restoration, your going to go thought the doors anyway. Now that you have them open, take them apart and clean them up. You were going to do it anyway. The insides are cheap and the reason they don
eholt80
