Reprogram keyless entry
djwendt
Albuquerque, NM
My 95 Bronco XLT was purchased used. It did not come with any keyless entry remotes. Just recently i inquired at a dealer to find out if it came on this bronco. They said to check inside the doors and see if there are actuators. There are actuators in there for the locks. I ordered a remote but cannot locate the connector to reset. Has anyone had to reprogram theirs, and if so how did you go about it?
Thanks for all the past info and help on this one.
Roadkill
Killeen, TX
Here is a link to some instructions, I have not tried this myself so I dont know if it actually works, but will cost nothing to try it.
http://www.fordf150.net/howto/reprogramremotes.php
Hope that helps.
When I checked the link in the post to see if it would pull up the page, I noticed that the intructions are for 97 and up Fords. I cant find a button to delete this post, so I used the "edit" button. Sorry for getting your hopes up. :blush:
Roadkill
Killeen, TX
Ok, I felt kind of dumb for posting bad info so I spent the last hour searching the internet for the right info. I finally found a link on Miesk5's page. Man, am I a '****! Should have looked there in the first place. Anyway, here is the instructions.
J. Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located at the base of the steering column. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. The door locks will lock then unlock to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. The door locks will lock then unlock to confirm programming
Here is the link to the site where I got it.
http://www.v8sho.com/SHO/Remote%20Keyless%...%2097-24-13.htm
I hope I have redeemed myself! :)>-
D
djwendt
Albuquerque, NM
Ok, I felt kind of dumb for posting bad info so I spent the last hour searching the internet for the right info. I finally found a link on Miesk5's page. Man, am I a '****! Should have looked there in the first place. Anyway, here is the instructions.Here is the link to the site where I got it.
Thank you so much for the info. I will give it a shot.
