high idle !!!
blackhoss89
Brown Summit , NC
I've got a 1989 ford bronco xlt with a 5.8 liter and an automatic tranny, when i start my truck it goes to idle around 1600 to 2100 rpm and im not sure why. I read another post on this website and the guy said he had the plenum gasket changed and it fixed his , our symptoms were similar and i was just wondering what the plenum gasket was ,where it went.how much it cost, and how easy it would be to fix by myself. thanks
ole betsy
st. peters MO
it might be a broken vacuum line so i would check that first. but a plenum gasket is the gasket where your lower and upper intake meet. the gasket is pretty cheep, should be under $10. there is 5 bolts and a torx bolt holding the upper intake to the lower, youll have to unplug a couple of wires and 2 hoses going to your throttle body and unplug your vacuum lines on your upper intake. it should be fairly easy. good luck
