suspenison lift first timer need help
mikefl0718
Warrensburg, MO
i am planning a 4" suspension lift for my 85 bronco, but instead of buying the expensive kits i am buying it in sections, i already have the coil springs, shocks and the lifting blocks, my question is, do i need to get some extended radius arms or anything else?
Thanks,
Mike
green streak
Thanks,
Mike
if you're on a budget, just buy the drop down brackets for the existing radius arms. if you're piecing one together, be prepared for weird handling charecteristics and premature tire wear. good luck.
