**** while driving
snowman74
Oklahoma
1988 XLT 4X4 W/OD
[Thanx Ill check it out.I know what you mean.Ive lived in Detroit,Phoenix area,Boston area have
stayed in New York and LA a few times there is no worst traffic or driving conditions anywhere than L A. :excl:
LA is bad...but Dallas is pretty bad too. I hate going there. The rush hour is more like a crawl hour.
Just because I'm not certain about the lingo, what the heck is a "pumpkin?" And, no smarta$$ remarks about the orange fruit please. :))
Snowman74 :)>-
Ralphdb
Lakeland Florida
I didn't know a Pumpkin was a Fruit..? It could be shutting off for a sec. when you let off the gas. this will cause a big ****.. You might make sure the idle is up at 800 then see if it still does it. Try some good fuelinjection cleaner also..
mbtech2003
cape cod, mass
just a shot in the dark but how about play in the drive shaft slip joint or it just may need to be lubed. plain wheel bearing will do. make sure u mark the shaft so it goes back together in a straight line. also check springs or the spring mounts. they have a habbit of rusting out and breaking. :)>-
WileE7
i had the same problem with it jerking when i drove it would shut off when i put it in gear and just wouldn't respond when i stepped i=on the gas i changed my speed sensor, TPS, and my fuel pump now it runs great my fuel pump was going bad that could be something to look at
broncokenny
Ken Emerson
Michigan
I changed fuel pump but didnt change filter till a little later cause it was fairly new.Think i could of
damaged fuel pump if there was blockage in filter?And were is the speed sensor?Or TPS? :)>-
snowman74
Oklahoma
Yep, as are tomatoes, squash and bell peppers believe it or not. I'd just never heard of the diff. housing being referred to as a pumpkin. Makes sense.
I'm anxious to know how this turns out...whether it's a fuel related problem or a drivetrain related problem. My first inclination would be U-joints. I'd replace them all. I had a kind of wobble feel when driving about a year ago. Had a guy look at it and he said it was the drive shaft. He said it was bent and/or out of balance. He was full of sh*t. I replaced the U-joints and whammo, no more problems. (I also went to a buddy and had the drive shaft tested...it was perfectly fine.)
Snowman74 :)>-
WileE7
your speed sensor is on the transfercase
http://www.supermotors.net/getfile/231830/...-sensor-003.jpg
your TPS is under the throttle body have someone check your fuel pressure when you turn the car on and check it again while its running thats how i found out what my problem was once i changed my fuel pump my Bronco's been running great good luck
steechfinger
new jersey
i was thinking have you checked your exhaust manafold gaskets and bolts if there was a leak there it could make a **** cuz the preasure in the cyl. wouldent be balanced just a thought
