CRAZY IDLE
Dan 2663
I JUST DONT KNOW. KOEO CODE 11, now KOER CODES 21, 44, 33, 72, 73, 74, 65. mY COOLANT IS LOW i JUST INSTALLED A NEW EGR VALVE AND SENSOR IAC, ECT, MAP, EGR DIVERTER, CHECKED ALL VACCUM LINESECT... DIRING COLD START UP AND FOR THE FIRST MILE IT RUNS THE BALLS BUT AS SOON AS ITS WARM I START GETTING A LITTLE HESSATATION AND CHOPPY RUNNING AND A IRRATIC IDLE, AGAIN FOR THE FIRST MILE ITS GREAT, IF I UNPLUG THE SPOUT IT RUNS SMOOTH AS A KITTEN. I HAVE BEEN TRYING TO FIND THIS PROBLEM FOR ABOUT A HALF YEAR NOW.
HAS ANYONE EVER HAD THIS PROBLEM BEFORE I HAVE TRIED JUST ABOUT EVERYTHING EVEN A NEW FUEL PUMP, FUEL PREESURE REGULATOR, PLUGS, WIRES, CAP ROTOR, AND EEC-IV. HHHEEEELLLLPPP.
DAN
wtfdissux
Buffalo, NY
have been chasing the same ghost for about a year as well but the latest thing is for no reason i burn my coil to dist wire out as in the coil end turns to a lump of carbon type crud so now thinking that ignition may be in the mix of probable causes so am gonna try new coil and dist.
as well as related componants
mine gets bad enough on occasion that i have to drive with 2 feet to keep the idle from falling to low an stalling
Well, I don't see the TPS (Throttle Position Sensor) on your list of parts.
D
Dan 2663
Hi and your right ..... but when I pulled the codes it did not come up... KOER and KOEO.. maybe its intermitting or something. I could pull the throttle body and replace it, I need to do the water pump too so it might be the right time... it'll be drained. But during the rainy days it seems to be almost not happening, but like today nice and Dry its doing it all the time after the warm up. I JUST DO'NT GET IT...
ANYONE ELSE WITH THIS PROBLEM
Dan
D
Dan 2663
sound like my problem too... two foot driving, my problem almost disappears when its raining out but not totally dissapears
Dan
