my 91 ford bronco won't start
Gary1987
i was driving my 91 bronco 351 efi, when it just shut off. I let it sit over night the it started right up the next morning, so i went about 5 blocks from my house and it died again let it sit for about 5 mins then it started again went about 10 feet it died and has not started since. The engine is turning but not starting. i replace the engine computer,coil,checked for power at dist,coil, and checked for fuel all was good, but the damn thing still won't start. PLEASE HELP
If you have a pickup in the distributor, that is the exact symptom of a bad pickup. However, you didn't say what engine and Ignition system you have. Is it a 302 or 351, EFI or Carb.?
G
Gary1987
24346[/snapback]
I have a 351w efi, if it is the pickup how hard are yhey to change?
brizzy351
Camarillo, California
24340[/snapback]
There could be a number of things it could be. Start by checking the fuel pressure to the fuel rail with a fuel pressure tester to eliminate problems with the fuel pump. Check the computer for trouble codes that might send you in the right direction. You could have a bad fuel line or a bad fuel pressure regulator.
live_wire_318
FUEL RELAY
sounds like your engine isnt getting enough fuel so check that entire system
American Rebel
4x4 Trail Master
Chesapeake, VA
24346[/snapback]
I believe a distributor in a 91 Ford Bronco doesn't have points. I know the one in my 88 Doesn't, and it's a 302.
I'm stumped, I don't know what could cause the no-run problem. :wacko:
jhollma
I had something similar happen. It was the fuel pump
