No start on 83 bronco
Ccarder85
Destin fl
I have a 1983 bronco with the inline 6 replaced fuel pump the other day and now it won’t start turn key on lights come on but once I turn it to attempt to start the power cuts off any ideas what wire I knocked loose in the process
Hey Ccarder,
Sounds really simple, but check your battery cables. Make sure theres no corrosion between the posts snd the clamps.
If thats good, check where the pos cable connects to the solenoid in the fenderwell.
Good luck
C
Ccarder85
Destin fl
Hey Ccarder,
Good luck
Appreciate the response did as you said also went as far as replacing the solenoid and no he’ll still not even turning over just cuts the power
Cuts power, So head lights go out too?
Or try cranking engine with headlights on. If the headlights go out, you have a connection issue somewhere.
Also, have you tried with a set of jumper cables? What happens then?
Arizona Sportsman
