Not starting
Kerr
Wisconsin
I have a1993 Bronco 5.0. Replaced coil - plugs - Distributor cap - plug wires.
Used firing order as was listed. Have spark But do smell gas when trying to start. Ran good before I changed these
Parts. Not firing up now. What could be
The problem. Thanks
Yo Kerr,
Welcome to our Bronco site!
See How to Troubleshoot a Bronco No Start @ https://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
Find out if speed control, if equipped, recall work is completed.
If you still have concerns about Recalls, please contact the Customer Relationship Center:
For the hearing- or speech-impaired: Please contact the Telecommunication Relay Service by dialing 711.
... have VIN ready.
See this guide by member jowens1126 to confirm recall status @ 93 & 94-96 Cruise Control Recalls Repair
For any Bronco questions or to chat about desired modifications or build, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as Bronco and Ford Parts/Accessories (50 posts required to participate due to scammers who preyed on our members ).
See 93 Body/Chassis and Drive Train Manuals @ 1993 Ford Truck Service Manuals - Google Drive
In pop-up, Click "Drive"
Here is the 1993 Bronco Dealer Brochure in Google Drive @ 93Bronco.pdf
1993 Bronco Dealer Training Video via member silver70 @
1993 Bronco, Venezuela Commercial @
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via member BroncMom!
See my mostly recovered site by member schwim @ Ford Bronco And F-150 Links - FORD BRONCO
It contains boo-koo component repairs, installation & parts sources.
Motech
Santa Cruz, CA:
That's your key there.
Firing order should be 15426378 counterclockwise.
#1 will be cast into the cap for reference.
Ford changed the 5.0 firing order to the 351 order right around 94/95, plus most aftermarket cams use it too, so it yours has been modified, chances are it's now 13726548.
paul rondelli
Atlanta
Make sure you are at TDC on the compression stroke for number 1 cylinder. to set the timing
I made the mistake of trying to time her when I was at TDC of the exhaust stroke for cylinder 1
The compression stroke has more pressure
wyo58
Laramie WY
The problem. Thanks
Do you have spark at all cylinders? Did you replace the rotor? Is it the correct rotor ( looks like the old one ). Sometimes go simple first then check your firing order, usually if your order is all one off on the cap it will not fire and if it does it can fire through the intake. You did not mention that you changed timing so it should not be that. Just go back of everything, also make sure it is the correct coil as well, it should be an "e core coil"?
The problem. Thanks
Welcome to the club. Did the parts store sale you the correct coil? Their is a difference between a electronic coil and a point coil(as on older vehicles) They did me. Did you check the gap on the spark plugs? Its best to check all the plugs right out of the box. Look up in the boot of the new plug wires. Some of them are off( the part were attaches to the plug) sometimes will not completely attach on the plug stem. Check ALL of them. I even found them off in my NEW MOTORCRAFT PLUG WIRES. Also their are counterfit parts out their. I,d start buy putting the old coil back on and make a check off list as I would check everything. Good luck.
Also check the rotary button and hopefully you got the cap and rotary button with the brass tips. They have a better contact then aluminium and lesstrouble.
tsebalj
