1990 Bronco XLT
armymedicmike
Tennessee
I have a starting issue. It is getting fire, fuel, and air. It will turnover but will not start. Starter is good, timing is spot on, and changed plugs and wires, replace coil and module. Any ideas as to what it could be.
5.8 or 5.0?
Try using starting fluid that can tell a lot. Like incorrect firing order. Or maybe it will run fine on starting fluid.
An actual fuel pressure reading would be helpful. 90, so it has 2 fuel pumps? One in tank and one on the frame rail?
Yo armymedicmike,
Welcome to our site and Thank You for your Service to our Country!
As Tiha advised, and;
See How To Troubleshoot A No Start (Ford 4.9L, 5.0L, 5.8L) @
Contents of this tutorial:
  1. Difference Between A No Crank And A No Start.
  2. No Start Condition Basics.
  3. No Start 1: Checking For Spark.
  4. No Start 2: Checking For Fuel.
  5. No Start 3: Checking Engine Mechanical Condition.
  6. No Start Summary.
  7. Related Test Articles.
Here are the 1990 Bronco Pre-Delivery Shop, Emission and Electrical & Vacuum Troubleshooting Manuals (EVTM), Partial by member Kingfish999 in Google Drive @ 1990 Ford Truck service manuals - Google Drive
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf found by BroncMom!
See my mostly recovered View attachment 202203
site by member schwim @ Ford Bronco And F-150 Links - FORD BRONCO
Have tried starting fluid and still a no go. It's 5.0
How many miles are on this thing? Any idea?
If it doesn't run, spit back through intake or exhaust on starting fluid then one of two things are happening.
No spark or No air
No air meaning, Like a broken or skipped timing chain. valves not opening at the right time.
Compression test is where I would go next.
Motech
Santa Cruz, CA:
I was thinking bad MAP sensor, but starting fluid would overcome that.
So now I'm thinking weak spark.
Try disconnecting SPOUT connector, the ignition timing bypass plug. If it starts, or even tries to, you likely have a bad PIP sensor, the pickup coil inside distributor.
If that's the case, a reman distributor i# the cheapest and easiest repair. But with 100K, you'll want to replace the Ignition Control Module and Ignition Coil too.
Don't overlook plugged exhaust. When you have air, fuel, and spark and she won't light, you are stuck at valve\ ign timing, fuel quality (the starting fluid will disprove this), and last plugged exhaust. I've seen it a few times. It almost always messes up the guy diagnosing
hope that helps
cheers
Motech
Santa Cruz, CA:
Don't overlook plugged exhaust. When you have air, fuel, and spark and she won't light, you are stuck at valve\ ign timing, fuel quality (the starting fluid will disprove this), and last plugged exhaust. I've seen it a few times. It almost always messes up the guy diagnosing.
Boy Howdy!
(Typically causes some intake snort & backfiring too)
mindy
